Need to identify fuse block "terminals"
What are they for?
What are they rated?
Are they fused?
I have determined they supply 12 volts when the key is in either the On or Accessory positions.
- 1970 Sport Custom long bed, 360 C6 2WD -
- jimmy828
Re: Need to identify fuse block "terminals"
You're right. I hooked a tachometer to one of them but i added a inline fuse to tach
It appears they are there as additional accessory terminals. I would advise adding an additional in-line fuse to any circuit you add.
- Dan
I just hooked up my accessory VOLTS gauge to one of those blades with an inline fuse also, works great.
