removal of blower motor 75 f100
cannonballdale
Post by cannonballdale »
Hey everyone im pretty new on this site but its helped me alot i was wondering if there was a certain way to remove the blower motor housing without removing whole dashboard the whole vent system gets wedged into in and i can't figure out how to remove it
jimmy828
Re: removal of blower motor 75 f100
Post by jimmy828 »
If you are trying to take the complete unit out take coolant hose's off to start with. Look under the hood looking for bolts that come threw firewall on passenger side. The bolts have speed nuts on them and should have a rubberized sealant around them. There is a pair of defrost ducts on top of that unit that will have to come off also. Be careful with the ducts they might be brittle and could damage them when handling. There should be a rubber boot from the kick panel to the box that will have to come loose. You should not have to deal with the dash at all.
