More grounds and hot taps
sargentrs
Post by sargentrs »
Not my truck, project's stalled, but my '74 Dodge Dart. Really tired of whole hassle of trying to find a place to tap into a constant or switched hot source for things like gauges, cigarette lighter, 12v phone charger, mp3 player, HEI ignition, etc. So I figure I'll run some additional wiring so I have more constant/switched 12v sources. Question is...
Is it good to ground everything to the battery negative terminal? Plan on using these http://www.ebay.com/itm/251795214723 to give me some decent taps on the battery posts and, along with the starter relay and engine block ground, run a hot line to a junction block and from there to a relay to a separate fuse block under the dash. Then a ground line from the battery to another junction block and to a terminal strip also under the dash. Another ground for headlight relays, along with hot taps for those relays, too. That'll give me 6 fused taps for accessories, additional constant hot sources from the junction block, multiple sources for ground both in the engine compartment and under the dash, etc. I'll be upgrading to a 90 amp alternator in the process. The wiring on this car is in sad shape and want to bypass as much of the original as possible. I just had some concerns about routing everything from the battery. Not too happy with the guys over at the Mopar forums so I thought I'd come home to here and ask a great bunch of guys I know and respect. Still picking parts but here's a few of what I've found so far...
http://www.ebay.com/itm/231232172533
http://www.ebay.com/itm/231008053482
http://www.litecycle.com/collections/gr ... s/sg-eb-6p
Any advice, input, concerns, etc? Thanks guys!
HIO Silver
Re: More grounds and hot taps
Post by HIO Silver »
I wouldn't run individual grounds to the battery, a Dart is a unibody, right? A good ground anywhere on the unibody is electrically the same as any other ground on the unibody. To hedge, weld individual ground studs where they are most convenient.
sargentrs
Post by sargentrs »
Thanks, HIO!
