1971 f-250 turn signals no longer flash
Chico
Post by Chico »
Hello
My 71 f-250 suddenly does not have flashing turn signals. They stay on solid. All other lights work fine and the emergency flashers work too.
Tried searching to see if the flasher could be the problem. Was gonna get one and know its a 13350 but not sure which specific one.
I could really use some help from you all.
Thanks.
1971 F-250 428
Re: 1971 f-250 turn signals no longer flash
From the factory the tss flasher is hooked to the back of the isnt cluster. The e flasher also has one hanging down near the lower right side of the wheel.
