Electrical gremlins
Electrical gremlins
As of lately, my dash gauges and my fan blower will suddenly quit working. I take off the battery ground, replace it and it works fine until it decided to do it again. Has anyone else experience this? It is a 1969 Ford F100 Ranger with full instrumentation.
1969 F100 Ranger 2WD 3 speed manual. Swapped 360 for 300I6.
- samericsson67
Re: Electrical gremlins
Do you're tail lights stop working too? Mine did the same thing. It was that green ground wire near the back of the frame.
There should be a ground wire from the back of the engine to the firewall
is that there?
is that there?
Yes, but I will replace it with a longer one that leads directly to the block. I had swapped a I6 into it. The one on it now is from the v8 and will only reach the rocker panel cover bolt. Will try new strap and post results.cep62 wrote:There should be a ground wire from the back of the engine to the firewall
is that there?
Worn ignition switch. Try wiggling the key next time. If it worrks then u foynd the problem
