Brake Light Switch
Flightman91
Brake Light Switch
Post by Flightman91 »
Good evening,
My brake lights keep sticking on. Worth trying to fix? Or should I get a new one? If it is worth fixing how would I go about doing so?
Thanks Guys
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
Mach428
Re: Brake Light Switch
Post by Mach428 »
Check the adjustment of the switch to the pedal first and go from there. If you pedal has alot of play in it, you would need to compensate by adjusting the switch further away from the pedal so that it is only activated when pressure is applied by your foot.
Get a new one
