1972 ford f100 head lights
jlb
Post by jlb »
Does any one know, Can I get headlights at auto zone, napa, or something like that?? or do I need to order them online? I didn't know that that would be maybe a stock item?
THANKS
jb
Mach428
Re: 1972 ford f100 head lights
Post by Mach428 »
Yep, most auto part stores will carry them. You can also upgrade to Halogen for a few bucks more
HIO Silver
Post by HIO Silver »
7-inch round sealed beams or halogens.
Consider upgrading the wiring with a headlight relay harness... $30 through LMC and it is decent.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
jlb
Post by jlb »
Thanks guys. I found a couple of head lights at the local auto place..
sykanr0ng
Post by sykanr0ng »
You can get housings to convert to H4 bulbs and then use LED or HID bulbs if you want.
The LED bulbs have an amazing lifespan, low current draw for their output and resist vibration well.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation/authenticity...
HIO Silver
You may need to clearance the headlight buckets in order for modern headlamps to seat properly.
