need help with charging issue
kurupt72
Post by kurupt72 »
I have a 72 f100 that wont charge the battery. i have changed alternator and voltage regulato twice each. still does not charge battery holds charge. is there something im not checking or missibg i need it for work and its my everyday driver.
tqwrench
Re: need help with charging issue
Post by tqwrench »
What tools do you have at your disposal? DVOM? Test light? VAT-40?
One commonly overlooked item is the negative battery cable. One way to check that is to use a pair of jumper cables directly from the battery (use one cable) negative to the engine block and see if the lights and all other items start to get brighter when it's running.
1969 F-250 390 Camper Special
Candy Apple Red/Wimbledon White
chad67
Post by chad67 »
Have you done any other work to your truck recently? Gauges, other wiring?
1967 F100 SWB
SoCalRefuge
Post by SoCalRefuge »
Check the condition of the wires going to and from the alternator. I had a problem where the v/r was putting out voltage but the alternator was never getting it. As a result it was not putting out any power.
SoCalRefuge
~67 F250 390~
Deadeye
Post by Deadeye »
Hey, Did you figure out your charging problem? I am having the same issue with my 71 ranger. If you got it figured out could you let me know what the problem was? Thanx Deadeye.
Mason56
Post by Mason56 »
Had the same issue in my 71 and my uncle, who is a postal mechanic, had an old diagram from his shop for the old Ford shop trucks. My voltage regulator had nothing in the top terminal slot and his diagram showed a jumped wire. We added a flat connector to the top slot on the regulator and then jumped it to the bottom connector wire with a short piece of wire. Problem solved.
kurupt72
Post by kurupt72 »
Yes I solved the charging issue. It was with the wiring on the voltage regulator. Somewhere along my trucks life someone had played with wires leading to it and didn't put them together correctly so after cutting the loom and tape fixed the wire. Its running like a champ again.
