Sorry guys I dont mean to beat a dead horse but some of the posts on here about this subject just seem to die off so I am going to ask the question and hope to get the right answers.
I just got a 71F100. It has a 360 in it if that actually matters but from what I have read it does matter if it has a light or a gauge, mine has the ALT light. SO a little back story, I got the truck running today and decided to take her for a spin when I noticed that the ALT light was on. Previous to the test drive when I had it running at the station I did take off the + side terminal to see if it would stay running and it did. So after the test drive I started looking around and noticed that there was only a wire going to the battery side of the alt and a ground wire from the battery to a post on the back of the alt as well and thats it. The alt is a ac delco alternator. What I am looking for is the correct way to install this so my light will work correctly and so also the alt will charge correctly.
Thank you in advance.
3G 1 wire swap
3G 1 wire swap
1971 F100 Custom w/ Explorer package. 360, C6, LWB
- guhfluh
Re: 3G 1 wire swap
Need to know what alternator you have to make recommendations. Are you trying to get your stock one to work or upgrade to a 3g alt?
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
Re: 3G 1 wire swap
Its actually a gm alternator but I found what I was looking for....finally got everything hooked up correctly. Thanks for the reply I had no idea you had. I didnt get any notification of the reply.
