Ign switch
Mancar1
Ign switch
Post by Mancar1 »
Finally got around to changing out the ignition switch on the 68. Took a few minutes and sure is nice not to have to jiggle the key around to fire er up. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Re: Ign switch
Post by sargentrs »
It's the little things in life :D
68RGR
Re: Ign switch
Post by 68RGR »
Mine was kinda "loose" a while back. Not to the point of not working - Just kinda loose.
Then, while working on the emergency brake pedal, the dumb switch came apart. I wasn't touching or operating the switch. There wasn't even a key in it. The vibration from releasing the parking brake was just too much for it to stand, I guess. That's when the fun began. As in smoke. The part of the switch with the wires still attached managed to short itself (read: WELD ITSELF) to the underside of the dash.
Wasn't long after that I installed a circuit breaker in that line.
Bill
68 F100 Ranger
73 F100 Ranger XLT
daveford72
Re: Ign switch
Post by daveford72 »
68RGR wrote:Mine was kinda "loose" a while back. Not to the point of not working - Just kinda loose.
Or a nail in the fuse holder !!! :evil: :eek:
68RGR
Re: Ign switch
Post by 68RGR »
Dave - That was the problem - The wire (black with yellow stripe) that ties to the + side of the solenoid and feeds the yellow wire going to the ignition switch is NOT fused. If your switch comes apart, as mine did, you could have a really good chance to lose your truck to a fire. Thus, the circuit breaker.
See:
Bill
68 F100 Ranger
73 F100 Ranger XLT
