horn works off and on
- Mancar1
Put a 72 column in my 68 CS. I am using the 68 steering wheel. Got it ground down to wheel retaining nut so the 68 horn ring would fit on. Get all back together and the horn works. Drive the truck the next morning and horn doesn't work. took wheel off and got the horn working. Next day horn doesn't work. went through this a few times, sooner or later I will find the glitch in the widget whatchamacallit.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- abe
Re: horn works off and on
The PO put a 71 steering wheel and column in my 70 F350. The horn didn't work. I bought a whatchumacllit thingie as many said the little copper wire breaks. I rented a wheel puller but could not get the wheel off..?.
So I put a plastic horn button on the steering columns and hooked that up to the horn relay and I now have a reliable horn....
1970 F-350 flatbed dump, purchased 9/20/12
1954 F-100 bought from Grandpa in 1977 for $200
- Mancar1
Thanks for the reply abe. Ya it is the contact acting up on my horn. I am going to mess with it when I get over this darn crud that has set in. Don't give up on that wheel they can be stubborn, but they will come off.abe wrote:The PO put a 71 steering wheel and column in my 70 F350. The horn didn't work. I bought a whatchumacllit thingie as many said the little copper wire breaks. I rented a wheel puller but could not get the wheel off..?.
Have a great day. John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- wildcard
Mancar1, sounds like you just need to drive it every other day. You don't even have to thank me for that bit of wisdom.
I had to pull my steering wheel 3 times on my 85. I either finally got it right or it got tired of me beating my head against the dash.
Man, I hate anything to do with the inside of a steering column.
Good luck.
Good luck.
- Mancar1
Thanks for the fix wisdom. I am just going to drive it on the days the horn is workingwildcard wrote:Mancar1, sounds like you just need to drive it every other day. You don't even have to thank me for that bit of wisdom.
Good luck.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
