tail lights all out! driving at night...FIXED Thanks
KRob
Post by KRob »
Someone just pulled up next to me and told me I had absolutely no tail lights. My head lights are working. Is there anything I can easily check to see. Its dark, rainy, and I have next to no tools. Thoughts?
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
sargentrs
Re: tail lights all out! driving at night
Post by sargentrs »
If your flashers work turn them on to start. If not, check if your brake lights are working. If they are, loosen the nut on your brake light switch enough so your brake lights come on. That'll at least get you home without being rear ended.
KRob
Post by KRob »
Everything in the front works nothing works in the back. I saw no blown fuses. I didn't see any wires hanging below.
HIO Silver
Post by HIO Silver »
It's dang near impossible to troubleshoot over the web... It rests on your wrench-worthiness and that awesome tool between your ears to figure it out.
KRob
Post by KRob »
Well i am home. So i guess i will have to take a look tomorrow in the light.
My first guess is a i jammed a stick up there some how and ripped the wires out. But will see. Looks like i am going to be spending a lot of time with a test light.
Thanks, for the speedy responses, i was hoping there was something i was over looking like a second fuse panel or something.
motzingg
Post by motzingg »
bad ground through the bed?
do you have a trailer wiring harness, i've owned a couple trucks with badly hacked-in trailer harnesses that have shorted and killed the rear lights.
KRob
Post by KRob »
Motzigg,
You are correct....bad hacked up trailer wiring harness. I have not started looking yet though. So no idea right now.
motzingg
Post by motzingg »
yep yep.
there are two plugs just behind the axle that connect the whole rear harness. i'm planning on re-doing mine from those plugs-back, probably this weekend, and adding a 6-pin RV plug. i'll post schematics and pictures when i get around to it.
KRob
Post by KRob »
You know.....i don't think its healthy for part of your wiring harness to get wrapped around your steering shaft. So any way problem found.
Thanks.
