Reverse light come on with power
hotrod ford
Post by hotrod ford »
I just installed a B&M shifter in my truck and had to install the revers light and neutral safety switch wires to it according to the instructions. Now when I even turn the key over the reverse lights automatically come on. Just for good measure I switched out to each terminal on the shifter switch. All had the same results. Any ideas?
hotrod ford
Re: Reverse light come on with power
Fixed it. Had to adjust the switch itself. Good to go.
