Purchased $400
DMV Transfer & Nonop $50
Driver Window $15
Regulator $15
Seat $25
Carb Rebuild Kit $17
Tank Solution $15
Fuel Pump Filter $5
In Line Filter $4
Rear Brake Shoes $24
Rear Brake Drum Turned $16
Rear Brake Drum New $31
Fuel Pump Bowl,Washer Bag,
Battery Hold Down Clamp & Bolts,
Fuel Gauge Sending Unit, Turn
Signal Switch $142
Shift Collar, Gas Cap, Front Wheel
Bearings and Seals, Axle Snubber $88
Air Cleaner Assembly $45
Total To Date: $856
Plexiglass Rear Window
Beat Down Steering
Ready For Paint Before Installation
The Dash Lights Were Dim So I Pulled The Old Tape And Installed New Clear Tape
Radio Wouldn't Turn On
Soldered In A Jumper Wire And It Works Fine Now
