Series of holes around back window
afchief
Post by afchief »
Hello. My 68 has a series of holes drilled around the rear window. Any idea of their use? Stock or add on? It's a Custom Cab, if that makes a difference.
-1968 F100, LB, 360, Auto, Custom Cab
bluef250
Re: Series of holes around back window
Post by bluef250 »
PO removed the rear window and installed camper pass through with RV Boot or gasket.
ToughOldFord
Post by ToughOldFord »
bluef250 wrote:PO removed the rear window and installed camper pass through with RV Boot or gasket.
:yt:
