Hi guys,
deleted post - figured it out
Thanks!
Bill
Decoding the old 6 connector camper wiring
- Roodaddy
''72 F350 Crew Cab
'72 Galaxie 850 Camper
Re: Decoding the old 6 connector camper wiring
That's great that you figured it out. It would be nice if you could share what your problem was, and how you fixed it. That's the whole point of this forum.
- Roodaddy
I deleted it because I was so embarrassed by the simplicity and near stupidity of the question. Essentially, I bought a new multi-meter as the old one was damaged…don’t ask…. Once prepared I got some needed exercise by repeatedly getting into the cab and flicking switches then laying down to check the meter and decipher the wiring pattern which is…from Left (Front) to right (Rear)
Pin #
1 -12V ground, white
2 Right signal, green
3 Left signal, yellow
4 Marker lights, Black (modern is brown)
5 +12V accessory, Red (modern is black)
6 Backup, Black/Red (modern is blue)
It’s a shame the original camper harness is impossible to find, but I made do by hacking the wires out of the original connector and slicing into a harness I made.
Thanks for calling me on it.
Cheers,
Bill
''72 F350 Crew Cab
Thanks for sharing. It's good stuff to know. Here's a diagram showing the camper wiring.
