3157A LED performs worse ...
basketcase0302
Re: 3157A LED performs worse ...
Post by basketcase0302 »
Coulda' swore I remember someone here stating that the instrument panel lights get power from the IPVR, (making it less than 12 volts powering them). But when I look at this diagram I see them getting 12 volts from the headlight switch:
I would put a digital volt meter on the socket of the panel lights just for grins and giggles and verify the voltage there before condoning the new bulbs. Please let us know what voltage you read there.
fireguywtc
Post by fireguywtc »
I know if you remove the IPVR that all the dash lights don't work.
Bill
basketcase0302
Bill, I believe that the IPVR reduction in voltage, (around 6 volts) also feeds the instrument panel lighting. I just can't "see it" or how it's done on the above wiring diagram. :oops:
70_F100
Post by 70_F100 »
Instrument panel lighting is controlled by the headlight switch.
It's wire #19 that goes through a 2 amp fuse then to the instrument lamps.
The rheostat in the headlight switch is what controls intensity.
Not saying that Bill is wrong (there may be some grounding issue when the IPVR is removed), but the IPVR is on a totally different circuit than the lights.
basketcase0302
:doh: I knew that Richard, just forgot I guess as I've had so many of them quit on me! Check the rheostat on the headlight switch. A lot of times I'd just bent the "arm" to put more pressure onto the spring assembly of it to make them work. Might also want to verify the voltage needed to make the LED's work-as I believe they do need a full 12 volts, (rheostat turned all the way up). If you have an aftermarket, (made in china) headlight switch in the truck-this is probably the fault. I'll never spend another penny on a "standard" brand (red & white box) anything electrical. :2cents:
Nitekruizer
Post by Nitekruizer »
The LED type bulbs use a special flasher. The old style flashers that came with our trucks won't flash them. Some of the LED bulbs have more LED's than others and have them arranged differently, so that can affect how much light gets reflected through the tail light lens. They also work best if the LED's are the same color as the lenses. Our trucks originally used 1157 bulbs so an 1157 LED would be best. The 3157 may not be the correct replacement LED. :) IHTH
fitzwell
Post by fitzwell »
little late to the party, but..Dash lights are 12v, off the switch. One thing about LED's, they are great if you have a straight "line of sight". Once you get about 15 deg. off of direct, they are worse than regular bulbs. just my :2cents:
VirgilJordan
Post by VirgilJordan »
basketcase0302 wrote:Coulda' swore I remember someone here stating that the instrument panel led lights get power from the IPVR, (making it less than 12 volts powering them). But when I look at this diagram I see them getting 12 volts from the headlight switch:
[ Image ]
I dont think there is any worse performance.. I have been using them for years and I think no other lights perform better
