Hello I was wondering if anyone knew what the brown wire that plugs on the small stud on the rear(the I stud) of the solenoid was I did a EFI swap and I don't think the car had anything on that stud and I wasn't sure if I still needed it hooked up or not
Thanks
What is the brown wire that connects to solenoid
Re: What is the brown wire that connects to solenoid
Wire #262 to 16A I believe is the ignition bypass that sends power to the coil.
Maybe someone else can chime in here that knows a little more.
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Thank you guys so since I now have the EFI setup and coil is controlled through the computer I don't need it hooked up anymore correct?
- 1970 Hi-Boy
I would say you are correct.
