Voltage Regulator Question
davbell22602
Post by davbell22602 »
What was Fords reasoning for putting 5 terminal on the voltage regulator for the horn?
basketcase0302
Re: Voltage Regulator Question
Post by basketcase0302 »
davbell22602 on Mon Apr 02, 2012 3:58 pm
Dave, do you mean the relay for the horn? :hmm:
davbell22602
Yes, Why is the horn wire going to voltage regulator?
basketcase0302
Dave,
Here the yellow wire comes off of the battery/hot side of the solenoid to power the horn relay. Not real sure about it coming off of the voltage regulator-maybe certain years it got power from there instead?
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Post by 1970 Hi-Boy »
Got me curious, had to take a peak under the hood of the old girl. It's wired like in the diagram above but what that doesn't show is that it runs in the wire loom going to the voltage regulator, being they are right next to each other. A lot of similar colored wires there and if double backed, would give the appearance of coming from the voltage regulator.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
davbell22602
My 67 has horn wire going to the voltage regulator.
davbell22602
Is there anyway to bench test a voltage regulator?
SmoothJ69
Post by SmoothJ69 »
I've had the regulators tested at my local parts store before, like autozone or whatever. if they can test an alt, they can test a reg also. As far as self testing, I have no idea..you might find something on google, but then again you might cook it in the process.
SmoothJ69
Post by SmoothJ69 »
Of course depending on your local parts store they might fry it also lol.
davbell22602
SmoothJ69 wrote:Of course depending on your local parts store they might fry it also lol.
Very true. I have some real quacks working at some parts stores here in town. Especially the one female at Pepboys that told me that gear reduction starters aren't made for vehicles with overdrive.
