72 crew cab cummins
72 crew cab cummins
here is the 72 cc i puchased. i know it has cancer but that is no problem i use to do body work so i am not afraid. my plans are to make it a 4x4 and it will have a cummins motor.
Re: 72 ford crew cab
hang with me guys i have alot of pics and i am going to jump around a bit.
here is the dana 60 i rebuilt it with new berings king pins ect
here are some pics of the rear it had a flat bed on it so i had to torch all the tabs off.
- Swegner99
Thats awesome, I would love to find a crew cab at all, let alone one in good shape. Good luck with the build!
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
1999 F150 Ext Cab
i got this one from kansas city mo. there are none around in ohio. The cool thing is i was rooting around in it when i got it and found all the org. paperwork it was a u p rail road truck still has the brass tag in the door.
- Swegner99
Its always fun to know the back story on these trucks, wish I knew where my 72 spent the bulk of its life...
1999 F150 Ext Cab
1999 F150 Ext Cab
heres the last few i have on here with the rear 4in superduty springs on i will try to download the ones off my phone in the next few days.
here are some pics of the dana 60 front mont being build and being placed under the truck.
heres more
heres the finished product. this thing is like a bus i love it.
This week i got the 79 steering box rebuilt. It took a whole 45 min to take apart and put back together. I fabed a bacing plate out of 3/8 and put slugs behind it also you can see in the pics i had to notch the frame i tacked a plate up in the notch. Everything is tacked in i will finish weld it all when i tear the truck down.
Wow you're moving like lightning on that thing!
1970 F250 Camper Special
trying to get alot done before the snow flies. i dont have a big enough shop for it so i have to work outside. ill post some more pics tonight or in the morn.
got some body work done. Figured i would do some while i was gathering parts for my rear dish conversion.
