Coil damaged by welding on the car?
Florian
Post by Florian »
Found out that my new Accel Super Stock coil won´t work. I wanted to fire the engine up the first time again today after I did some welding on the floor and so on. Didn´t start with the new coil but with the old coil.
Could the coil have been damaged by welding on the floor?
1971 Ford F100, 302cui, 3 on the tree
Dragon
Re: Coil damaged by welding on the car?
Post by Dragon »
yes it can It was looking for a good ground.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
BobbyFord
Post by BobbyFord »
I've never heard of a coil being damaged but it is always recommended to disconnect the battery whenever welding on any vehicle.
mr_josh
Post by mr_josh »
Considering that the coil was physically switched off if the truck was turned off, I think it's highly unlikely that welding on the floorboards would do damage.
Josh
'72 F-100 Sport Custom 4x4
papabug71
Post by papabug71 »
They say it COULD happen, but I never unhook anything when welding on my vehicles & I've never had any problems.
Im gonna chalk it up to coincidence :thup:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Dragon
Post by Dragon »
mr_josh wrote:Considering that the coil was physically switched off if the truck was turned off, I think it's highly unlikely that welding on the floorboards would do damage.
Actually if anyone knew electricity like I did it would be arced inside with the switch off or on. The welder needed a better ground so current took whatever path to get to a ground and the distance between the primary coil and the case was not enough to protect it from an arc spike. When you strike an arc with an AC or DC welder a spike about 20 nanoseconds wide will reach about 7000 volts in that time before dropping and it races to be grounded in every conductive path in the vehicle. Welding in the cab and most likely it arced over the switch contacts as one path to ground. Since the case clearance in a coil is so close the 7000 had no problem getting a ground.
Old Fords Rule
My Gallery
Spark test
papabug71
Post by papabug71 »
Or it could be a bad coil from the factory. This isn't the first time a s/s coil has been bad right out of the box.
Matt
Mine since 5/7/'94
Dragon
Post by Dragon »
I argued till I was blue in the face with Accel over an 8140 SS coil. They said no way running it with out a ballast resistor when used with a 2020 points eliminator would it burn out. I have it under my hood in the box where my new one came in a couple of months ago.
Old Fords Rule
My Gallery
Spark test
papabug71
Post by papabug71 »
A buddy in town with a 572 chebby vega had a hell of a time with them over burned up parts. He said they were total d*cks about it too.
He's running a Jesel belt drive dizzy on it now with alot of MSD stuff.
Matt
Mine since 5/7/'94
Florian
Post by Florian »
Sent an email to them on Tuesday but didn´t get a response yet..
Dragon
Post by Dragon »
Even though I am not happy with Accel support I am going to use some of their parts in the future. The 300+, http://www.accel-ignition.com/ProductDe ... election=1
the Jacobs coil http://www.accel-ignition.com/ProductDe ... election=8
and dizzy http://www.accel-ignition.com/ProductDe ... election=6 MAYBE
Maybe this dizzy though, http://www.msdignition.com/Products/Dis ... butor.aspx
Old Fords Rule
My Gallery
Spark test
