67" lift kit
1967mercury
67" lift kit
Post by 1967mercury »
i have been looking for a lift kit for my 67 m-100,and i cant find one anywhere....
is there a diffrent truck that has the same frame/suspension?
does anyone hve a link to where i can get one?
i dont want anyhting too crazy,just 3 or 4 inches,so i can comfortably fit 33 inch tires
1967 Mercury M-100
240 i6
3.03 trans
3300IB 9" 3.70 Gears
hazelnut
Re: 67" lift kit
Post by hazelnut »
Is your truck 2wd or 4wd ?
1967mercury
Re: 67" lift kit
2wd...i know that makes it harder still,but im not going offroading..
1967 Mercury M-100
240 i6
3.03 trans
Re: 67" lift kit
it should eb the same as the other years of trucks. the only thing to worry about is the springs it has on it. if it has the regular leaf springs or the flex o matic leaf springs that mat differ in the kits as to how it lifts the truck. the flex o matic springs were used on the F250 as well as soem F100 trucks.
1967mercury
Re: 67" lift kit
so i can get like a..72" lift and it would work?
what year did flexomatic come?
1967 Mercury M-100
240 i6
3.03 trans
1971ford
Re: 67" lift kit
Post by 1971ford »
My 2wd is "lifted".
You have to bend your i-beams and do it all yourself or pay someone else that knows what they are doing, or you can get an autofab kit for a few thousand, which are very nice and will be off-road capable speed wise.
-Ryan
1967mercury
Re: 67" lift kit
so...i have two diffrent awnsers,and i need to know witch one is right/better
1967 Mercury M-100
240 i6
3.03 trans
hazelnut
Re: 67" lift kit
Post by hazelnut »
the flex o matic are rear springs that make no difference on lifting you truck, the rear of your truck would be lifted with lifting blocks between the rear and the leafs to lift the rear. the front lift on your truck would go like 1971 says. you could buy new front springs for the front and have your I beams bent to align the front, buy some lifting blocks and Ubolts for the rear. new shocks and rubber brake lines will also be needed for lifting.
1967mercury
Re: 67" lift kit
so either way i have to have the ibeams bent?
1967 Mercury M-100
240 i6
3.03 trans
Caseys71
Re: 67" lift kit
Post by Caseys71 »
Pretty much, that or you'd have some serious camber especially with 4" of lift. But to do it right yes you would need to either bend your I-beams or buy a set of I-beams bent for a 4" lift.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
72Highboy
Re: 67" lift kit
Post by 72Highboy »
What about a body lift I am planing on putting a body lift on my truck but I also have a lift kit on it also. Just more :2cents:
Joshua
aka Young Gun 8) :drive:
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
1971ford
Re: 67" lift kit
Post by 1971ford »
Body lift... if that's what floats your boat. I wouldn't. Maybe a 1 or 2 inch max for me but then its not even really worth the trouble. You'll have to keep a lot of little things in mind like steering, front/rear bumper, engine will be lower in the engine compartment, clutch/gas/brake linkages, etc.
-Ryan
1967mercury
Re: 67" lift kit
i have anathor option,and that is to change over to a straigt axel set up and go from there
1967 Mercury M-100
240 i6
3.03 trans
1971ford
Re: 67" lift kit
Post by 1971ford »
Not worth converting a 2wd to 4wd... Time for a frame swap. Tons of fabrication needed because the frames are nothing alike. But if you have the skillz and money anythign can be done.
-Ryan
Redcap
Re: 67" lift kit
Post by Redcap »
Unless you are racing, I don't understand lifting a 2WD truck at all.
