points eliminator
fastlayne14
points eliminator
Post by fastlayne14 »
what did you use to convert your ignition? I have an msd 6al box and msd coil I need something inexpensive that will work with this setup.
Dragon
Re: points eliminator
Post by Dragon »
Cheapest unit on the Market and I have had it for 3 years problem free the Accel Points Eliminator.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
fastlayne14
iv read on some other posts that you can take the guts out of an electronic distributer housing and they will fit rite in the points housing I do have an electronic distributer from a 460 that I could take parts from, how hard is it to do that?
i have read that too. i have never tried it and i don't know how to do it. but it should be pretty easy.
Dragon
Post by Dragon »
Not if you don't have the later bottom shaft.
Old Fords Rule
My Gallery
Spark test
ForingaMex
Post by ForingaMex »
I did that with my distributor. Took a Duraspark (electronic) distributor from a 351/400 and married it with the points distributor from my 390. I don't know about others, if they will work but no problem with mine. I had to change the top portion of the shaft but not the bottom part. It's pain to get the top shaft off of the bottom shaft. (Small snap-ring in the hollow shaft under the rotor)
Jake
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
mrsnicks
Post by mrsnicks »
I use the pertronix ignitor. I'd love to upgrade to the Ignitor II... With the original if you leave the key on without the engine running it can burn up the module.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Dragon
Post by Dragon »
ForingaMex wrote:I did that with my distributor. Took a Duraspark (electronic) distributor from a 351/400 and married it with the points distributor from my 390. I don't know about others, if they will work but no problem with mine. I had to change the top portion of the shaft but not the bottom part. It's pain to get the top shaft off of the bottom shaft. (Small snap-ring in the hollow shaft under the rotor)
Jake
I see no reason to put a worn bottom shaft under the top guts of something with less wear. A Dura spark dizzy is just 46 bucks.
Though I love my points eliminator a Duraspark makes more sense as I get new bushings and shaft for better stability. So that is why I am moving that way.
Old Fords Rule
My Gallery
Spark test
HOWDY69
Post by HOWDY69 »
I have had an ignitor for 3 years. I had some problems but I am pretty sure it was the coil and not the ignitor. I now have a flame thrower coil and an Ignitor and it is working fine. I ran full voltage to the ignitor and used the original coil wire with the resistor wire for the coil.
Dragon
Post by Dragon »
You could still have timing issues if the ignitor was put in a worn dizzy. I had put a rebuilt dizzy i my truck then I put my Accel unit in. I could watch the timing jump as the engine revved up and sometimes it would bounce before I changed dizzys
Old Fords Rule
My Gallery
Spark test
ForingaMex
I was just replying to this statement. I'm just sharing my experience with my own dizzy and it worked without the later bottom shaft (for me). I didn't say anything about using a worn out shaft and I don't see any reason for it either. I just said that it does work. The rest is up to each individual, depending how much $$ he wants to spend and how accurate he wants the timing to be.
Jake
-Jake
Dragon
Post by Dragon »
I bring up worn parts to let people know that if they have some problem and think that adding the points eliminator will fix everything that it might not be true. My reason for eliminating the points is I grew up with them and the constant adjusting for wear was a hassle. The last 4 times I pulled my cap was to remove the front bottom float bowl screws.
Old Fords Rule
My Gallery
Spark test
Thunderfoot
Post by Thunderfoot »
Dragon wrote: I see no reason to put a worn bottom shaft under the top guts of something with less wear. A Dura spark dizzy is just 46 bucks.
Don't forget the ~$30 core charge on top of that... :doh:
Dragon
Post by Dragon »
5 bucks at U Pull and pay 2 core take that one to Autozone and get rebuilt for 46 so 53. Oops Autozone just went up to 48 and down to 20 core. I already have my cores for Duraspark II and wires from U Pull and pay.
Old Fords Rule
My Gallery
Spark test
cep62
Post by cep62 »
fastlayne14 wrote:what did you use to convert your ignition? I have an msd 6al box and msd coil I need something inexpensive that will work with this setup.
You can use a MSD 6A with a points dist
