Hard start First time of the day
We're slowly getting my 67 352 back to life but we're having some issues. We flushed the Aux tank and straight plumbed it to the fuel pump. First start of the day takes forever. Fuel pumps from the jets right away, take a bunch of pumping and full choke to start if it does. Once started and warmed up it runs good and starts in the first couple of cranks. We've sit timing and point to proper settings. Could the starter be drawing to much that there not enough for ignition? Was think of Electronic ignition, I seen a conversation thread here I though but can't find it. Any thoughts would be appreciated.
Re: Hard start First time of the day
Which carburetor do you have?
Does it crank over slower first thing then it does after it is warmed up? The only time I have ever seen not enough voltage to fire the motor is when the battery was almost dead and the motor almost not turning over...
To me this sounds like a carb problem with it emptying out of fuel over night...
- 70_F100
You say it takes a bunch of pumping or full choke to start. Are you getting fuel each time you pump the accelerator? If not, I agree with Thunderfoot
, the carb may be emptying itself overnight. Most likely cause of that is a bad check valve in the fuel pump.
If you are getting proper fuel, it sounds like it could be ignition.
You say you've set the timing and points. Did you use a dwell meter to set the points?
What timing setting did you use?
Did you just set the points, or did you replace them?
Did you replace the condenser (should always be replaced when replacing points) and spark plugs?
If you replaced the plugs, what did you set the gap at?
How old are the plug wires, distributor cap and rotor?
That's not an oil leak
