Custom I-Beams
Ditchdigger
Custom I-Beams
Post by Ditchdigger »
I'm looking into building a set of 3 1/2" dropped I-beams for a 66. I will need to modify the spindles (knuckles) for the tie rod location, the pitman arm will also need modification, so that the steering linkage will clear the stock radius arms. I'm planning on building jigs for my I-beam welding. I know I can buy dropped beams , but I don't like any that I've seen, mainly because of the tie rod relocators. I have seen a simular type of setup on Ward's Prostreet 66.
cobraF100
Post by cobraF100 »
Keep us up to date because here in the next few months I plained on getting a set of Drop IBeams to lower my Truck..
I'd rather Help a Fellow Member out before I bought somewhere else.
Chris
Never Forget Our Soldiers
Ditchdigger
I will try to take pictures before ,during , and after. That is if I don't forget like usual.
willowbilly3
Post by willowbilly3 »
I have thought about doing the same thing. I don't know why they can't make drop spindles like they do for others.
Ditchdigger
I have cut and installed my home built custom I-beams this past weekend. It ended up being a 4" drop. How does it look?My Photo Gallery
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
It looks pretty good from what I can tell. Now you're gonna have to drop the rear height so you don't like a stinkbug runnin' down the road! ;)
So the beams you're using you fabricated yourself?? Have you got some pics of those (closeups) that you could share?
cobraF100
Post by cobraF100 »
So,you want to make another set For Me?
Email me and let me know.
Chris
willowbilly3
Let us see close ups of the dropped I beams, then get ready to quit your day job. I want a set lowered for an F-250.
cobraF100
Post by cobraF100 »
You'll end up haveing enough business just from this site alone to keep up and going for a while..
I'm verymuch wanting to see some better Pic's of how it was done,and then ask you how much is Shipping!!!! :D
Chris
willowbilly3
re: Custom I-Beams
I just ran across a tech article over on the H.A.M.B. at the Jalopy Jurnal. They were showing how to heat and drop a model A axle but the principle would be the same. They look real clean and stock but of course they do come together a little in the process. I will see if I can figure out how to make a link.
