sorry I misread what you said in the first post...
I'm not sure what your truck's switch has there, as it should have 7 connections used for the wiper (5)/(4 to the motor+1 power) and washer (2)... Do your wipers have 2 speeds or just 1?
Did your truck have”power" washer/squirters on it originally? Some of the early 67's and 67's in general have some differences from the other years... (early ones have some carry over from the slicks wiring)
If it had a power washer before you should be able to wire the new one into the old wire harness out on the fender, Red should be the power and Black should be the ground on the new pump.
Here is the 67 washer diagram
http://www.fordification.com/images/sch ... wipers.jpg
Here is the 69 wahser diagram
http://www.fordification.com/images/sch ... washer.jpg
