What is the Dwell on a 390 motor?
marine6212
Post by marine6212 »
Hey Guy's,
I just got my truck running again :D I need to set the Dwell on it. I have a dwell meter but have no idea what the dwell shoud be? Can any one give me a idea what it should be!! This will be my first time using a dwell meter!!
Thanks,
Marine6212
We all came together, both young and old.
To fight for our freedom, to stand and be bold.
In the midst of all evil, we stand our ground.
And we protect our country from all terror around. Peace and not war, is what some people say. But I'll give my life, so you can live the American way. I give you the right to talk of your peace. To stand in your groups, and protest in our streets. But still I fight on, I don't bitch, I don't whine.
FORD428CJ
Re: What is the Dwell on a 390 motor?
Post by FORD428CJ »
I want to say its 34-36 for your dwell!?
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
rubiranch
Post by rubiranch »
26-30 degrees
72 F-250 CS XLT 390 C-6 4.10 40k miles
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
http://www.fordification.com/galleries/ ... ?album=514
stangconv
Post by stangconv »
timing = dwell?
ares360
Post by ares360 »
so is that the timing degrees or what?
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
dwell is the angle of the points. how do you set it on a ford i don't know. i do know that you have to use a meter. on the older gm's you could like a metal tab on the side of the dist cap and turn the allen screw to set the dwell. i turned that screw once and it didnt seem to do anything. i was 16 when i did that. and i never did it again becuase it didnt seem to do anything to my car at the time.
3rdowner
Post by 3rdowner »
24-30, I've always used 28. Never had a problem. Truck starts first time every time.
ED
mylifeswork
Post by mylifeswork »
I've always run 28 to 32 degrees on all V8 engines. On the ford you have to set it with the cap off and a feeler gauge. Use a .016" feeler gauge to set the points. Of course make sure the cam lobe on the distributor shaft is on the rubbing block of the points so it is fully open. This should put you in the ball park of 28 to 32 degrees. If you have a dwell meter you can then verify the dwell reading. If not you can leave it there. One thing to mention is always set the dwell before adjusting the ignition timing. Dwell adjustment will change the timing but timing will not change the dwell. Point adjustment should be checked every 3,000 miles for adjustment. The main reason points were done away with is they won't keep adjustment the timing is always off. Keeps us from getting good mileage and maintain good emissions. Electronic is always better. Stays in tune.
Follow your passion, you will always do best at what you love.
