351w spitting oil
James
351w spitting oil
Post by James »
Ok. I'm not exactly great at this, but I'm trying to figure out where the 351w in my truck is spitting oil from. By spitting, I mean when it's running it covers the driver side of under the hood in oil, and gets it right close to the radiator and fan.
It's not a very wide spray, probably 4"-5" wide and about 1.2-2 feet long.
Any ideas what gasket would be blown? Though to spite that, the engine still sounds like it's running like a champ.
I'm just hoping that it won't be an expensive repair and that it's not a "Rip entire engine apart" thing.
But for right now that's been bothering me and I'm currently unfortunately unemployed and trying to keep myself busy between applying around town and sleep.
http://www.cardomain.com/ride/2411268
My '71 F100 truck on Car Domain.
fitzwell
Re: 351w spitting oil
Post by fitzwell »
oil pressure sender???
Dragon
Post by Dragon »
Oil filter flange damaged? Sensor most likely.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
SteveC
Post by SteveC »
could also check the timing cover as well
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
theskytoucher
Post by theskytoucher »
Are you sure it is oil or could it be power steering fluid?? Just a thought!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
those are some good guesses. it could be any of those. the damaged oil filter sounds like the best one. here is my guess and i know i'm not wrong. "its coming out of the engine some where." :lol:
Bugsb70
Post by Bugsb70 »
Keep us informed if you change the filter. I have encountered a similar problem on my rebuilt 302. It was fine for 500 miles. At the first oil change it began pushing oil from the region around the filter. It's not PS fluid (first thought) and not the sensor. I will check the timing chain cover. I tried a simple oil change with a new filter, but the problem persists. Altough any loss of oil is serious, it is not a large amount.
