Did a bunch of wirin' today.
I got the new custom fuse block I made a month or so ago installed today...
It works like the a champ.
The feed post on the left is hot all the time. It feeds 4 circuits
The feed post in the center is hot with the key. It feeds 6 circuits.
The small block on the bottom right is fed from the light switch rheostat.
I did that so I could fuse the dash lights and other gauges separately.
click on pic to enlarge
Now, I have several open circuit feeds in case I wanna add stuff, which I do.
Then, I moved on to the camper.
I posted a previous thread about my campin' trip and how I had fried the wires from the deep cycle battery and had no power inside the camper... and that none of the camper exterior lights worked.
Well, I went through all the circuits and got everything working except the right side brake light.
It was beginning to get dark when I stopped messing with it.
Just about the time I gave up, I realized that the right rear brake light wasn't working on the truck either...
Anyone got any ideas where I should start trouble shooting???
Would a bad ground on the truck light cause both lights to not work???
The tail light and turn signals work fine on that side...
so I am a little puzzled.
Any help would be appreciated...
Thanks again,
KaptnKA
