The hood may fit, but is very wrong.
The '79 has a mated tranny and t-case. You can run it if you run the 79 front axle.
1979 to 1972 f-250 parts swap,scavenging
Moderator: Doug Comer
- averagef250
re: 1979 to 1972 f-250 parts swap,scavenging
The hood won't work unless you also use the dentside radiator support and hood latch. On our bumpsides, the latch is on the hood and the catch is on the radiator support, but on the dentsides the latch is on the radiator support and the catch is in the hood.
