Went to pick up the truck yesterday but ran into a couple of glitches
. 1st, the trailer wasn't avaliable so I figured I'd just redo the timing, get the plug wires into the correct holes, fire it up and have it ready to load when the trailer was ready. WRONG.
2nd glitch. When the PO (cheby man) had removed the distributor to redo head and intake gaskets he managed to lose the intermediate shaft. After a few questions he tells me that maybe he heard something fall. Yeh, right into the oil pan.
The engine had been turned over quite a bit and I never heard anything that would make me believe it had hung up any where.
I pulled the distributor and took a look into the deep, dark hole, and it ain't there. Well, that shot my day in the a**. Put everything back in the correct holes and called it a day. Stopped at NAPA on the way home
and got a new shaft, $ 9.00, will go back later and install it.
Now before I do this all again does any one think that old shaft lying in the bottom of the pan is going to cause me problems in the near future???
I'm not sure that's where it's at, I only know it's not attached to the distributor and the PO doesn't know where it's at.
It seems my Chilton has hidden itself from this old, blind man. It's been a long time since I had a ford apart so I'll ask.
The shaft has a round stop staked about a inch from one end, this is the end that goes towards the oil pump, right ???
Thanks in advance for any and all help.
CW
