Nuetral Saftey Switch
1970pickup
Post by 1970pickup »
I just swapped from a manual trans, original equiptment, to an automatic. Does anyone have an idea on what to do with the neutral safety swith and the back up light switch. I prefer not to jury rig the thing and would like to go as original as possible. Thanks Jack
flyboy2610
re: Nuetral Saftey Switch
Post by flyboy2610 »
Did you install an auto column or is it floor shifted?
Red Green
you'd better be right.
the neutral safety switch is on the lower inside part on the column in a automatic. if you haven't put a automatic column in then you should be able to leave what you had alne. if you did then you need to hook that up to the correct wiring in your truck.
Leadfoot
Post by Leadfoot »
depending on column or floor shift, you wiring is going to change a bit.
I don't know if you got the switch on the column or trans right now
SO
:hmm: for the safety switch the red wire blue line between the relay and ignition switch you add your switch in, almost every ford uses the red with blue line wire for a starter sol./relay/ feed wire so it should simplify things.
black wire red line is the back up lights. so you should be able to patch it in to the old back up swith plug off the std trans.
WHAT ?
Russell J
Re: Nuetral Saftey Switch
Post by Russell J »
Ahhhh! So the selector arm and the switch itself attach here?
And I should just follow the wiring recommendations but is there a plug setup somewhere under my dash for the old manual shifter safety switch? Not sure what I should be looking for under there to hook the new safety switch into.
CommrclDiver
Post by CommrclDiver »
My nuetral safety switch housing broke off my column. To kill two birds with one stone, I just wired it to a push button switch and hid it in the cab. Now it serves as an anti-theft device as well. :D
Work Hard, Dive Safe!
1971 Ford F-100 2WD LWB 302 w/C-4 Daily Driver
1971 Ford F-100 2WD LWB 302 EFI Project Truck
mrollings53
Post by mrollings53 »
And now your reverse lights don't work.
CommrclDiver
My reverse light switch is in the engine bay attached to the column.
