Headlight upgrades
- Galaxie64
Headlight upgrades
I've ran across lights such as these on ebay.
Anyone know anything about them or have any suggestions on an "upgraded" light for my '72.
'68 F150 2wd
'72 F250 2wd Camper Special (400/C6/4bbl)
'64 Galaxie 500 (3524bbl/57K miles)
'92 Grand Marquis (mostly stock 4.6L)
'97 F150 (heavily modded 5.4L)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
** Chuck Norris has counted to infinity -- twice. **
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- 390Nut
A friend of mine bought those for his
truck (cough-coughchevycough-cough) and they lasted about 3 weeks. One small rock (about the size of a pea) to the headlight shattered it on the drivers side, and it was wedged into the frame holding the bulb refractor.
Looks like a great idea, especially with a better, brighter bulb like those, but not worth the cost if the glass is that fragile.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- 67F250CS
The stock headlight wires are too small 18 guage and takes a very long path from the battery to hdltswitch,to the dimmer switch back to the headlights. Voltage is lost because the path is so long. You get maybe 10 -11 Volts. Intstall relays and you'll get back in the 13 or better range and you will notice a huge difference. Also this will cure the flashing headlight problem you see on some older Fords.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- adrianspeeder
This week I'll get my detailed headlight relay how too pics uploaded and written. Really helps with even stock bulbs.
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- Dropped 68
I bought a set for my truck and I have both good and bad to say, Let me start w/ the good. They look awesome, they give the front a really different look. And they have an aux blue lamp in them, (controlled by a toggle switch) When your in a parking lot or somewhere similar you can flip them on and oh man do they look cool.
The bad side, I had to make a couple very small mods to make them fit, and I doubt the quality is quite as good as something you would buy at the parts store. Overall, I'm very happy w/ them.
Charles
http://www.fordification.com/galleries/ ... ?cat=10451
http://s111.photobucket.com/albums/n146 ... =#imgAnch1
Build, Destroy, Rebuild!
- marz68
- 71 LONG BED
- cjs_72f250
re: Headlight upgrades
i just installed these today actually. so far so good. instead of wiring in the blue bulb, i plan to wire the "ring" wires to a switch in the cab. that way i can choose to light the ring around the headlight or leave it off and only have the main headlight on.
if i catch a rock in it and break it, i'm going to be pissed off
'72 F250 Explorer Camper Special
- rjewkes
My only problem on my first truck was that the driverside appeared to have been milled off a little.
Mine cracked from heat I got it and thought i'd go the 90 watt bulb. Wrong too warm for the bulb.
But even with that crack these where ultra brite with the stock wiring even when i went back to the 60/55 bulb.
