I am talking with Ratfink about the red carpet he is selling and have a question regarding the available sizes. LMC lists two options: column shift and floor shift. So are the transmission humps the same dimensions in both? If so, then I guess the only difference would be a hole cut for the shifter. Thanks.
jor
Carpet Dimensions
- jor
- flyboy2610
No. The floor shift has a higher hump. It's the same hump shared by the C6, BTW.
Red Green
you'd better be right.
Red Green
- jor
re: Carpet Dimensions
Thanks. So, if I understand correctly, a carpet sized for a truck equipped with an auto C-6 would be the same size as one for a 4-speed?
jor
jor
- flyboy2610
That's my understanding, yes.
Red Green
Red Green
Yes, C-6 trucks also had the removeable hump. Even though that tranny will clear a low-hump tunnel, it's tight.
