Anyway, I finally got started today. I decided that until I get the hang of it, and until I'm 100% convinced that this IS what I want to do, I'm just going to be painting a single front fender, going through all the steps of applying two layers and then wetsanding, and then repeating at least 3 more times. Then, if I decide I don't like the results, I can just strip the fender back down to bare metal and go from there.
So anyway....here's a picture of the bare fender I started with:
....and here's a shot of the fender with the first coat applied:
As you can see, the paint is applied in very thin layers. You won't actually get full solid coverage until at least the third coat. I kinda started getting a little worried here, because this was supposed to be a very dark blue called 'Aftermidnite Blue', but it's sure not looking like that to me!
....and a shot after applying the second coat:
OK, now I'm definitely upset. It's NOT the dark blue it was supposed to be. It'll get a little darker as additional coats are applied, but it's definitely not what I was hoping for. Oh well, it's not a major problem....it just means that for the final couple coats I'll have to mix some black in with the remainder of the paint to darken it up.
In the last picture you can definitely see the orange-peel effect. This is normal, and will be wet-sanded out after every other coat. That's what I'll be doing tomorrow morning, and then applying two more coats. Also, there's a trial-and-error method of thinning the paint AND in applying it, until you get the hang of it. I believe I did well applying the first coat, but think I got it a little heavy on the second. Also, I don't think I thinned it enough, because it should have layed down a little smoother. No big deal, that's easily remedied for future layers.
Anyway, like I said, I'll be hitting the shop bright and early in the morning, so that I'll have time to wet-sand this fender and apply the third coat, and then let it set up for the required 6-7 hours or so before applying the fourth coat. I'll post more pics tomorrow night.
