Well today I swapped out rear portion of drive shaft with the one from my donor. That seems to have solved the
excessive vibration I was having. Want to get a pro-shop to install new u-joints since this made it obvious I am not equipped to do so.
I reinstalled door panels and exchanged the temp gauge in the instrument cluster with the one from the donor. Have some questions about that.....
Also took wife for her first ride.
The tranny seems to shift nice and smooth but won't go into third gear. So at 50 mph the engine is at high rpms. I am thinking the transmission shift modulator valve or some more vacuum mysteries.....
For $14 I will replace it and see if that is it.
As for these pics, just an idea of how she looks on the outside.....I know body panels are not lined up,
in fact just bolted on enough to keep them on the truck.
Still need to get bed inside garage and get bottom cleaned up and reinstall on the truck. I need to install door gaskets and tend to all the body work I started. Think I will just sand and re-primer, then possible rattle can black or maybe just leave primer, until I can afford a real paint job.
You can trace this post back and see what the quarters used to look like. I think they are pretty ok for my skill level and general lack of attention to finer details.
Anyway, I could never be at this point if it was not for the great guys on here offering their expertise and help when I needed it most. Thanks
