1972 Ford F100 Project.
North56
Re: 1972 Ford F100 Project.
Post by North56 »
Put new bushings in the drivers side I-beam and installed I-beam.
popeyes71
Post by popeyes71 »
Looking good!
-Popeye-
1971 F-250 4x4 Highboy
hfdco4
Post by hfdco4 »
Great PROGRESS!
:fr: FE390PC
North56
Post by North56 »
Both I-beam bushings are in and the the I-beams are back on the truck. Waiting for the new Kingpins and reamer to arrive. It will be awhile till they arrive, having to cross the border from the States to Canada. In the meanwhile I will clean up, sandblast and paint the brake backing plates and spindles.
hdman90
Post by hdman90 »
Wow, you are crusing through this project! Can't wait to see the reassembly and see this thing look like a truck again! Keep up the steady work!
emeraldcoupe
Post by emeraldcoupe »
looking good. we could be twins :)
North56
Post by North56 »
[quote="emeraldcoupe"]looking good. we could be twins :)
They sure are close to being twins, nice job on yours. :)
Manny
Post by Manny »
Looking good. That old frame cleaned up mighty nice!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
popeyes71
Post by popeyes71 »
Very nice, she is looking good!
-Popeye-
North56
Post by North56 »
For a change of pace, I built the cab dolly for the truck.
Manny
Post by Manny »
I need a dolly like that! Cab coming off soon?
North56
Post by North56 »
Manny wrote:I need a dolly like that! Cab coming off soon?
I will probably take the cab off next spring, that is when I plan to do the panel work on the cab. My shop is not heated for the winter, it gets a bit costly when the temperature drops to -30C to -40C in the winter. :)
hdman90
Post by hdman90 »
Do you plan to reassemble and get it running in the mean time? Or will the project be on hold until spring??
North56
Post by North56 »
The project will probably be on hold till the spring. Will spend the winter getting body panels together for next spring. I want to price out rebuilt 302 engines also, see if I will do it myself or get a shop to do it.
North56
Post by North56 »
Sandblasted and painted drivers side spindle,brake drum and associated parts.
