I'm giving up ... trouble with the flabby gear arm on my Ford F100 automat
- Ranchero50
Re: I'm giving up ... trouble with the flabby gear arm on my Ford F100 automat
Use a socket that fits over the splined head. A 3/4" 12 point socket should work. Loosen the bolt and move it to where you want. Then snug it and test the door closure fitment before locking it down.
sargentrs. one question what is this for button ?? what does it do and how it works for what. have missed that I have one.
got some fun work this weekend.
Usually that hole is for the brake warning light. Comes on when your brake pressure is low. Operated by a switch on your brake distribution block.johnny55 wrote:sargentrs. one question what is this for button ?? what does it do and how it works for what. have missed that I have one.
Good job on the floor pans!
- Ranchero50
Ditto, brake warning lamp. Lights when the ignition key is in start and also when a brake pressure imbalance between the front and rear lines causes the indicating pin in the distribution block to shift and make an electrical switch. Pretty common for them to get broken or lost.
So, does anyone have the part number for the c6 shifter bushings? I ordered the 7343, and they are too thick. Thanks.
