chop top has begun for "el diablo" update11-7-14
customcrewcab
re: chop top has begun for "el diablo" update 7-2-
Post by customcrewcab »
looks really good. i am glad you only took 3 out. i was thinking around 2.5 would be the max but 3 looks great. so you just have to pie cut the doors and windsheild frame to bring it back to the roof? just wondering about the windsheld and the angle below the cut. does the gasket take up the differance in the angles?
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
gonzalo medina
Post by gonzalo medina »
Hey mars the truck is looking really good. I noticed your are running some other type of gauges.
marz68
Re: re: chop top has begun for "el diablo" update
Post by marz68 »
layedout72 wrote:i like it marz, it doesnt really even look chopped! i bet someone that hasn't seen one before wouldn't look twice at it being a chop. That in my opinion is how it should be! I do like the radical chops though and if I ever do my truck, i may go an inch farther than you have.
Not to much and not to little it's just right. :thup:
marz68
Post by marz68 »
customcrewcab wrote:looks really good. i am glad you only took 3 out. i was thinking around 2.5 would be the max but 3 looks great. so you just have to pie cut the doors and windsheild frame to bring it back to the roof? just wondering about the windsheld and the angle below the cut. does the gasket take up the differance in the angles?
I'll find out when I get to the shop today....the glass guy is going to be there working on the front glass. :D
marz68
Post by marz68 »
gonzalo medina wrote:Hey mars the truck is looking really good. I noticed your are running some other type of gauges.
Thanks!
Yeah those are stock 89 mustang gauges...they are only there to cover the hole :lol: ....not connected.
customcrewcab
:? now you got me thinking. i have measured it out acouple of times in the past. the fact that i would have extend the roof and the fact it i didn't like the doors looks then they where extend talked me out of it. i might rethink it. oh i think i got the clear tail lights figure out. finally got the plastic.
wt4speed#2
Post by wt4speed#2 »
I'm with layed , those are after(the chop) pics . It has to be the expanded back window . what kinda of small business.
We are not worthy bro :bow: :bow: , you are just wicked :rock: with that sheet metal stuff
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
layedout72
Post by layedout72 »
Marz, are you going to Reso 08? I am really considering driving out there. Not in the 72, but driving none the less. I figure if your guys from IF can do it to G-ville, we can sure as hell try! I really don't think it will cost a lot if (considering) if we have 4 people in the car. It's a 25 hour drive, should be like 6 tanks of gas each way. Hotel rooms are probably 100-150 for 4 nights. But between 4 people I bet we could get it done!
jzjames
Post by jzjames »
Very nice work and thanks for the pictures. So are you going to piece back together the rear window frame to give you a new configuration?
customcrewcab
so did the windshield fit? :? :? :? :? :? :? :? :?
marz68
Post by marz68 »
customcrewcab wrote:so did the windshield fit? :? :? :? :? :? :? :? :?
All I know is that it's going to cost me $400 for a new glass and seal, the guy measured the opening and is working on it now.
marz68
Post by marz68 »
now it's time to work on the doors, once that's done the work will move to the back glass. These pics are from this weekend.
customcrewcab
re: chop top has begun for "el diablo" update 7-09
looks good :D so the roof is welded in? 400 not bad for new seal and windshield and having them both cut down an install.
rjewkes
Post by rjewkes »
So its just a mild chop? not bad.
marz68
Post by marz68 »
400 is not bad for new glass I also get to make payments :lol:
3" chop looks good I just wanted it to be propotiond and not go to wild.
