A couple months ago I got my passenger side exhaust manifold replaced. It had a huge leak in it ever since I got the truck. I can not believe how quiet the truck is now with the stock manifolds! It sounds like a regular vehicle instead of TAT TAT TAT TAT.....
A couple of weeks ago I installed the headlight harness that 390Nut made. This was a very well made product as the rest of you probably experienced.
The battery tray and innner fender aren't in too bad a shape. I'll probably want to replace the battery tray but the inner fender just needs some wire wheel and new paint. Thank god for California weather. I cleaned them up a little and gave them a coat of Krylon Rust Tough in the mean time.
I also purchased these "Euro Style" halogen headlights from LMC.
The problem I had with these headlights is that the back of the assembly has this large rubber cap that holds the bulb and keeps the elements out. Unfortunately, that rubber cap doesn't fit through the hole in the headlight bucket so the assembly won't fit all the way in by about 3/16". My solution was to use longer sheet metal screws to hold the headlight ring on. This works, but it would be better to make the hole larger I think. I just don't have a good tool to do this with yet.
I attached the relays to the inner fender here and ran the harness under the starter solenoid. It's a nice fit.
Then I ran the harness to the passenger side over the core support, as 390Nut designed it.
Here are some before and after shots. As you can see, I had some aiming problems before I switched out the headlights.
BEFORE
After
It looks like I can still work on the passenger side aiming a little.
BEFORE
After
The pictures show the difference, but the actual real life results are even better than you can tell here. It is way, way better lighting now.
