Mercury Trucks 1967 1968 ID and details...
- snake
Re: Mercury Trucks 1967 1968 ID and details...
I have recently inquired about a 1967 Mercury M100 that is for sale and found this thread very helpful for identification purposes. I have read through this thread but i apologize if i missed the answer to this question:
I'm assuming that the Ontario plant produced both Mercury and Ford pickups so the assembly plant code for Ontario in and of itself is not sufficient to confirm a true Mercury pickup - correct?
Thanks for all the great info here!!
"It's better to be hated for who you are than loved for who you're not....." Van Zant
"If you can't say something good then there's nothing good to say...." Big and Rich
- mk
That's true; Fords and Mercs were both built side by side on the lines at Oakville and San Jose. The best bet to truly confirm a '67/'68 Merc is to get one of Kevin Marti's reports. There's lots of fakes out there. Look carefully at cowl nameplate mountings and under the hood for filled holes to eliminate the obvious ones. DSO codes are also quick indicators as per information given earlier.
mike
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
~Will Rogers
- mk
Here's a couple more late production '68 Merc reports...
Both of these were built at Oakville. More examples blowing away the fairy tale of production ending in march '68.
If there's anyone reading this that actually sold these trucks in '68 or was employed at Ford and has relevant information regarding the end of Mercury production, or even assembly line pics, please feel free to contact me. Thanks!
In respect to most trucks pictured in this thread, I regret to say I have not seen them since the pics were taken and your guess is as good as mine where they finally ended up.
mike
mike
~Will Rogers
~Will Rogers
Hi all, great forum! I’m new to this so apologies for being late to the party. I’ve attached pics of my 68 mercury and the Marti report for it. I’m always looking for more 68 mercury trucks so any leads are appreciated! Thanks!
Beautiful truck! Stop by The Welcome Mat nd introduce yourself and your truck!
and
from Georgia!
http://www.fordification.com/forum/viewforum.php?f=1
- mk
Here you go, Brad
...interesting that no radio or power steering were ordered originally; pretty sparse for options. Dealer could make more profit adding stuff later. Cool to see the dana 60 5 bolt diff. They're pretty scarce
~Will Rogers
~Will Rogers
I’ll contribute to this page, I just picked this M250 up from northern Idaho and hauled down to Northern California, was pulled out of a barn a few days ago near Edmonton where it sat for the last 30 years. It’s a late production 68, only 4 digits off from serial number of the crew cab posted earlier. In absolutely incredible shape
- mk
Thanks for sharing that! The repaint looks pretty good. The serial is actually about 50 trucks prior to the tan crew cab.
Interesting that Marti calls it just the 'custom' package instead of the custom cab pkg. There was no Custom label before '70, when it became the base model. The custom cab pkg became the 'sport custom', and of course, there were the two levels of Ranger. Also interesting the orig owner didn't spring for the gauge pkg or power brakes. Truly fascinating how many possible combinations these trucks could be assembled into. These were obviously the days before the marketers developed the art of combining options in more sensible packages.
~Will Rogers
~Will Rogers
- mk
Interesting items available in 1/25 scale from a great resin caster...
The flareside gate fits '53-'72 short flareside models and the regular gate will work for '65/'68 trucks. The thin pieces are the '65/'66 merc front letter panels below the hood. He also offers hubcaps and fender nameplates; and as an aside, a corrected wheelbase '73-'79 box for the amt series. A model company named moebius has brought out our trucks in 1/25 scale and these will fit those. The cab has fairly obvious proportion problems, unfortunately, but these roof problems can largely be rectified by grafting in the cowl/windshield and front half of the roof of the amt f350 series cab. A link to a visual of this process can be seen in the 'moebius f100 issues' thread at the 'modelcarsmag' website. Sadly, the '67-'69 grills were badly botched as well but an outfit called 'rookie resin' had made some nicely corrected grills.
~Will Rogers
~Will Rogers
I came very close to successfully building a Mercury "clone" truck back around 2010, (I found a 68' Mercury in NE Georgia and most of the lower body was toast from it's Canadian winters in salt) but the tailgate was pristine so I was gonna use it to start a Mercury clone-along with proper badging etc., (but the tailgate was pristine so I was gonna use it to start a Mercury clone-along with proper badging etc)
- FLASH 1
ONE Thing I have seen is many Mercury clones on the 66 to 68 trucks due to the fact on Vin # and the 65 and below cannot be cloned without serious number changing and big reason is those trucks had a totally different set vin numbers and not the F10 you would find now back in the late 40's 50's might be totally different again
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
Cool thread, I figured it could use a bump! I know this is outside the '67-'68 parameter, but it's my only Merc., and thought some may like it.
'61 Mercury 350
Sadly, it is so rusty it's become a parts truck, (tow trucks get used in the worst weather imaginable). I bought it for the windshield, which will go in my '62 unibody, and have used the mirrors on my F700.You do not have the required permissions to view the files attached to this post.
F. Noble, Saskatchewan.
- mk
Welp, here's what the new moebius '68 Merc 1/25 scale truck model builds up like...
not my build
not my build
~Will Rogers
~Will Rogers
Good to see this, I like that it even has a Canadian license plate. Mercurys are getting hard to find now, my brother used to have a red and white '67, that combination seemed to be really really common, and I was once told that was because it was the colours of the Canadian flag, but that's probably BS.
Not to nit pick, but '68 had side reflectors, rear were common with Ford. Mercury had amber ones on the front fenders, I once had a '68 Bronco, which used the same thing. Carpenter now re-produces them for Bronco, so if anyone is missing theirs, you can get them now, the rubber pad is different though.
- mk
Rather toylike proportion wise but the badging is well done. Moeb is also coming out with a '71 equipped with a wrecker body and duals. Could use that and the reissued amt '63 unibody, (converted to reg cab) to build that '61 wrecker in your post.
~Will Rogers
~Will Rogers
