1968 F100 2wd style side short bed.
sargentrs
Re: 1968 F100 2wd style side short bed.
Post by sargentrs »
Craigerf100 wrote:I'll do the spray test sargent. What am i spraying? The carb start spray? What are the symptoms of a leaking intake manifold in regards to the engine? Bogging, low idle?
Yes, and yes. Also, your idle would could possibly be spitting and sputtering, poor fuel economy and loss of power. Carb needs good vacuum. Would overall run not up to full potential. I always expect to see a good, steady 19-21Hg of vacuum when I set my timing or tune my carb.
sargentrs
Post by sargentrs »
Craigerf100 wrote:So I'm having trouble finding a missing piece of my park brake. I'm missing the Y - part. Whats it called? And where can I find it? I've looked through all my parts books.[ Image ]
Are you talking about the bottom piece in this picture? It's the parking brake equalizer. Got the other parts too, the thick bar and the adjusting bolt? Since you've got a short bed I don't believe you have the C clips that connect extension cables. Bronco Graveyard sells this one http://shop.broncograveyard.com/Equaliz ... nfo/12687/ that says it's for '73 and up F100. Looks like it'll work.
Craigerf100
Post by Craigerf100 »
Cool thx sarge
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
Craigerf100
So last night I did many things to the truck. One being lowering the front end a bit. I cut one coil out. And it dropped it about 3/4 of an inch. I was shooting for an inch, close enough for now. Can u tell it's been lowered? I did this so that the tire an wheel would fill in the wheel well along the fender more. While not rubbing the fender. Ill drive it like this and see if I've reached that goal. Or it needs another fourth or half inch. The first pic is before the last is after.
Before
after
sargentrs
Post by sargentrs »
I see a noticeable difference. Looks good to me right there. :thup:
Craigerf100
Thx. It's enough for now
Craigerf100
Before and after :)
Craigerf100
Fan relay installed as well. I grounded the black wire going to the temp sensor. And instead installed a switch to turn it off if I need it.
Craigerf100
Ok by the way I bought a vacuum guage/tester. And both the booster and trans are getting 18 in/hg. So i eliminated that possibility.
Hose to trans
hose to booster
Craigerf100
Replaced my front shocks. Rear ones will be next once I get that rear sway bar in. Found out its on back order :(
Craigerf100
Next will be figuring out why my transmission takes a few seconds to go into drive all of a sudden. So i figured a new fluid and filter wouldn't hurt. Engine and trans are not original. So Hmmm which transmission do I have.
found this nifty chart to help. Well it can't be a c3 or medium case. I have servo so it's not an FMX (thank God), hmm removable bell housing so it's not a c6. C4 it must be :) is a c5 an AOD?
Oh I'm also getting a deeper pan just cause. Wouldnt hurt.
Craigerf100
Some parts I'm thinking about getting.
Craigerf100
Another good chart.
dailyf100
Post by dailyf100 »
Craigerf100 wrote:Some parts I'm thinking about getting.
[url=http://s70.photobucket.com/user/craiger ... q.png.html]
Hood scoop
:( :doh: :hmm: :nono: :hw:
Craigerf100
:yes:
