Factory 4bbl manifold. It appears to be popping only, haven't seen any flamage, it does it when accelerating from no/low speed. If I'm at a cruising or highway speed I can romp on it and everything's fine.
Drove it about 40+ miles today, at one stop about halfway through it popped so bad it blew the vacuum cap off of the PCV fitting on the carb, (I'm using the stock carb spacer fitting for my pcv.), and it was a new cap that was pressed on pretty hard! With such a huge vacuum leak the truck wouldn't idle and my brake booster wasn't very effective. I stopped at a parts store and picked up some new caps and I'm back to where I started now.
Sure sounds like it has to be the carb to me, don't know where else to go at this point.
