67' longbed build
Re: 67' longbed build
Me? Wa state. Its a bit rainy but i got some new wiring and gonna get some work today hopefully.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- 71PA_Highboy
lots of bumps in JY's there... and no where near as rusty as what I am currently digging thru....
Where in WA? ...Kitsap, Kent, Snohomish and Benton counties for me....
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Ya my trucks pretty solid. Needs mechanical and electrical.
Im in puyallup pierce county off.canyon rd.
Got next.to.nothing.complete or.done tonight. I changed my solenoid to starter cable and battery positive. Havent messed to much with my alternator wire or circuit breaker wire.
Same thing. I have power but when i go to turn the motor. Nothing. Crazy how it ran before off battery with a dead alternator and a busted cicuit breaker i could use for a mocherana.
Go to unbolt my starter. Which i did. But apparently.my headers need to go 1st.
That will be a minute as i have broken off header bolts on both sides. Thinking ill tear if down from the top down. Carb and valve covers. Manifold.
Thatll give me more access to those pains.
Edit. I did manage to get the bed mostly pressure washed. And the front.of the truck is now on stands.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
According to the vin. Its a san jose california truck.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Thats the inside of the support charlie. Looks like just a nut and bolt. I tried to get u a pic of the motor side of the mount but its too tight, maybe with daylight.
Ill see about that wire for ya.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Hey I saw that you swapped your voltage regulator out. I had swapped mine with one that looks just like your new one and it made it so it wouldn't run. I put the old one back on and it started right back up. Mine was doing the exact same thing as yours. Worth a shot.
Kyle
Kyle
Even though its rattling and somthing might be broken inside? I guess i could open it up. Its deffinatly worth a shot. I think these little boxes are adjustable. I just dont know much about that. Ill swap it and try it. Bolt the starter back up.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
I just know that the voltage regulator I got looked just like yours and it was junk. I got mine online for cheap.
Kyle
Kyle
https://youtu.be/lYdYc6hdIao
Hope this is.ok here. Im gonna.try and do this with my header exhaust.bolts.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Yeap that's the mount setup I got that's what I needed to know thanks never know what's been changed over the years. Now if you could help me figure out those wires I'd be set.
Where does the black wire with the red stripe ground to coming off the alternator.
- pedro69ford
it grounds to the voltage regulator.should be black w/ red stripe out of alt to v/r bolt for ground than it carries from there thru green with red stripe to charge indicator lamp on the instrument panel and back down to the fuse box and switch black with green stripe..
Alrighty thanks what about the big fats black wire with the yellow wire next to it coming of the alternator /regulator harness does it go to the starter relay on the fender and which side
- pedro69ford
Thats correct, they connect to the positive side of the solenoid switch on the inner fender along with the black w/yellow stripe..
Alrighty thanks for all yalls help
