'70 Crew Cab
Re: '70 Crew Cab
drop a plumbob to the center of the axle mark the frame where the string goes down the frame. then put your springs on the axle center the plumbob and there you go. Just make shure the frame is sitting level whin doing this.
- mybros71
Re: '70 Crew Cab
Hey, I just saw your post about the dash pad removal. I did this before and like it. I dug the grills out of the old pad and installed them in the defroster duct opening. It worked slick an was free. They are caked with poly foam or whatever it is but once you clean them off and paint them, they're ready to install with a couple of screws each.
Tony
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
- dolinick
Re: '70 Crew Cab
I remember your grills. I was thinking about trying to get mine from the old dash pad but haven't messed with it yet.mybros71 wrote:Hey, I just saw your post about the dash pad removal. I did this before and like it. I dug the grills out of the old pad and installed them in the defroster duct opening. It worked slick an was free. They are caked with poly foam or whatever it is but once you clean them off and paint them, they're ready to install with a couple of screws each.
Tony
2003 7.3L F250
1968 F500 Utility Truck
Re: '70 Crew Cab
Yea that's what ill be doing but I need to know where to locate the axle at in conjunction with the frame firstsmokey3215 wrote:drop a plumbob to the center of the axle mark the frame where the string goes down the frame. then put your springs on the axle center the plumbob and there you go. Just make shure the frame is sitting level whin doing this.
- dolinick
Re: '70 Crew Cab
I removed all the air conditioning related equipment last night. I was assigned yard duty at work. Basically I had to sit all night at the "drop yard" all night starting at 6:30 p.m. and watch the trucks and ask everyone who came or went to sign in. Not a single person arrived or left. It was very slow so I decided to do a little work on the truck. So I removed what I believe to be the condenser, the copper tubing and the compressor. It looks better without all that junk. Now I wish I had a smaller bracket for the power steering pump instead of that big one for the a/c compressor and power steering.
2003 7.3L F250
- FormerMarine1981
Re: '70 Crew Cab
I bet that looks a lot better. I was planning on doing that myself eventually
- dolinick
Re: '70 Crew Cab
I think I got a great deal on this old truck. It runs really good! It's smooth at 80 on the interstate! It has plenty of power as well.FormerMarine1981 wrote:I bet that looks a lot better. I was planning on doing that myself eventually
Once I get the choke (manual) fixed, the exhaust manifold leak fixed, new power steering belt(and tightened) and maybe a new windshield she'll be even better.
2003 7.3L F250
- dolinick
Re: '70 Crew Cab
Hauling water: http://www.flickr.com/photos/dolinick/s ... 4076/show/
Truck and me at work: http://www.flickr.com/photos/dolinick/s ... 8434/show/
2003 7.3L F250
