1972 F-250 Highboy Restoration
- averagef250
Re: 1972 F-250 Highboy Restoration
Looks pretty nice!
How well is the powder coat stuck to those castings? Just curious, went down that road a few times before and always had terrible adhesion on anything with crossections thicker than .200" or so.
Yes, Transforce HT. It was either that or the original looking Traxions found at STA. I went with the Firestone radials.
80 lbs. of pressure in them!
Kevyn
1972 F-250 4x4, 390, Dana 44, 24, 60
- Manny
Transforce will drive nicely for sure. You turned me on to those STA tires though i have been looking at the old style power king tires so sweet another alternative. I have about decided to buy some nice AT tires for the aluminum wheels on my truck now then have a set of old school steels tires, and hubcaps for classy looking times.sopikp1 wrote:Yes, Transforce HT. It was either that or the original looking Traxions found at STA. I went with the Firestone radials.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Averagef250, Manny - I will keep you posted on the powder, but I will say I can't imagine anything much tougher.
I hope it holds!!!
Just got my bolts back from the plating co. today, I hope to start more assembly soon, but we're staring down a winter storm and may 10" of snow!
Thanks for the posts,
Kevyn
Kevyn
Kevyn
Here are a few pics of my hardware back from the plating co., and the front axle, and some other misc. parts.
Assembly will begin again tomorrow!
Kevyn
Hardware in black oxide, new u-bolts for front and rear, the front I could not find the original style - I just had these made in Omaha. With the help of Fordman, I was able to locate NOS rear u-bolts at an old Ford dealership in Monticello, IA.
Mounted the steering gear to determine the amount of material we need to remove from the radiator support, radiator and shroud.
Have a great weekend,
Kevyn
Kevyn
Kevyn
- Manny
Wow you are doing quite a snazzy job there. Did you have to slice that core support for that steering box or not??? Enjoying your pics and progress.
Manny, we haven't trimmed it yet, but we will have to. Radiator and shroud too.
Kevyn
What a Super Bowl! Prior to that we did manage to get the rear end bolted up, and some brake work done. I can't seem to locate original style e-brake cables and that did hold us up. I thought the cables I had from NAPA were right on, but no such luck.
If anyone knows where to find them, I'm all ears. I was referred to green sales earlier, and I will try them.
Kevyn
- 67mann
You can try these guy's.... http://www.cgfordparts.com/index.html don't really see any listing,but if ya have a part # to work with
Thanks 67Mann, I'll try anything at this point.
Kevyn
- averagef250
I have some nice ones from a '68 F-250 4x4 with 39K actual miles (it was ordered with 4.56's and sat in a carport forever since nobody wanted to drive it). My truck's lifted and has a newer axle so I don't really need them. Is this something that would work or do you need new?
I would be interested in them if he passes on them.
Steve
Steve
Thanks average250, I can re-use my own, but was looking for NOS. I appreciate the offer, it looks like Steve could use them.
Take care!
Take care!
Kevyn
- FoPAR
Nice build, keep the pic's coming
"FoPar" because I love Fords and Mopars so just call me FoPar...
