Thanks Stephen. Lots of workstephen44 wrote:looking good !
Updated 1-24-14 My weekend project truck, my daily driver.
Re: Updated 5-28-12 My weekend project truck, my daily driver.
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
This past weekend 6-2-2012 I sanded down my floor and painted it. I'm going to hopefully get the flooring installed soon, I run out of time.
Re: Updated 6-6-12 My weekend project truck, my daily driver.
Well I finally finished painting the inside cab area and just need to install flooring and get my seat redone. Ill try to get some pictures soon. Wow what a difference, I'm very happy!
Installed Flowmaster mufflers, clear parking lens, tint windows and now just waiting to get seat recovered and floor put in. I will get pictures up one day!
Re: Updated 8-6-12 My weekend project truck, my daily driver.
Clear lens & tint shot
Re: Updated 10-3-12 My weekend project truck, my daily driver.
Performed drum to disc brake conversion this weekend and wow what a lot of work it took to complete. A few problems I run into was I couldn't get the bearings to fit the spindles because of surface rust. I had to sand that off to get them to fit after spending a hour at the part store thinking I had the wrong size. I break the flare tool that I rented so I had to order another one so that held me up. I finally put everything back together and I had a few leaks in my lines, because the flare weren't made correctly so I had to redone them. And the other wasn't tight enough. I bleed the brakes and then the bleeder valves both break and started leaking fluid over the place. Finally got everything tighten up and took it for a test drive and it stops on a dime now. Way worth the trouble I went through to have stable braking system.
Some photos
More photos
- flyboy2610
I take it you did the king pins as well? That's what I'm working on right now.
You will love the way that truck stops with discs. It made a world of difference with Frodo!
Red Green
you'd better be right.
Red Green
Oh yeah a world of difference is right! Stops great! Thank you for your help on this project, well worth the wait. Gained the knowledge too!
Re: Updated 1-16-13 My weekend project truck, my daily driver.
I finally gathered all the parts I need to add power steering to the old girl. Ill keep you posted and Ill add pictures when I perform the install.
- occupant
JP your truck looks awesome as expected. This is about how I want to work on whatever I get next. Drive it, enjoy it, and every weekend find something to make better, one piece at a time
Alan Moore | TOAD Towing | Columbus, OH
00 Suburban "Moose III"
Strong Bad I | Strong Bad II | Strong Bad III
Thanks bro! A lot of work and time.
- mcheath
Just found your project thread and really enjoyed reading it. I'm on a somewhat similar track with my F250, not planning a serious restoration on mine, but a lot of cleanup/updates like you are doing. Your trucks looks real good.
Thank you, I still need to make time to add the power steering install info. But keep in touch!
