Chronicles of the Blue Goose!
- dablack00
Re: Chronicles of the Blue Goose!
This truck needs more blue!
Really though, I would at least pull the steering wheel and get some paint thinner and clean all that off. Next I would get some carpet, a new seat cover and pull and paint the heater box.
Past the interior and the blue overspay in the engine bay, the truck looks great. Have fun with it.
Austin
Austin
- SoCalExile
Well I just realized I hadn't taken any pics of the interior with the column swap. The one that's in the pics here is from a '76 (says so in paint pen on it,
). Since I got to TX I swapped out the column and steering wheel. I'll post some pics up later.
Eventually I want to pull the seat and put in something with headrests. Not sure about carpet...kicking around the idea of putting some bedliner on the floor instead.
- fomocoguy
So how does that 400 run with the performance gear set and headers? Was there a difference in the "seat of the pants" meter?
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- SoCalExile
A little bit. The motor is pretty tired, and the tranny needs some work, so it's not to the point of smoking the tires from a straight start.fomocoguy wrote:So how does that 400 run with the performance gear set and headers? Was there a difference in the "seat of the pants" meter?
- SoCalExile
More pics:
Haven't done anything with it lately. Money's tight, and I need to get the tranny rebuilt/replaced.
that is the rear breather hose should go to frame and have a one way valve on the end so bugs wont get in.
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
- SoCalExile
- SoCalExile
Crossing my fingers as I start my Duraspark II conversion.
- SoCalExile
- Florian
Looking good so far man. Let us know how the Duraspark conversion works out. I will be doing this once some good weather comes around. Taking the 300 I6 out and dropping in a 351C with a 4 spd from a 78 F-350.
70' F100 SWB, 300 I6, 3spd converted to floor
- SoCalExile
Speaking of the Duraspark conversion. Today I took it apart and put a piece of vacuum tubing around the little arm to further limit the advance since I didn't have a 10L plate around. Now the 400 runs very smooth and sounds like a car motor despite the glasspacks. So far no more detonation. I'm glad I did the conversion; and I should've done it in the first place instead of putting in the points conversion.
Did you fill in the holes on the dash or did you get it like that? the holes that would normally be for the dashpad.
I'll get it one piece at a time and it wont cost me a dime...
The hose off that brake junction is the breather line for the rear axle. It mounts aft towards the bumper along the frame.
Semper Fidelis
68 F350 Crewcab 390
68 F350 Crewcab 390
all your missing is a front windshield sticker. And nah I didn't steal the name from you. Just happened to find this post when I was on here
