1968 F-100 Ranger
re: 1968 F-100 Ranger - Picture Heavy (3-25-2006 update)
OK, the next project that I tackled was switching out the rear axle. I have an F-100 and the previous owner had switched in a Dana 60 30 years ago because he had a camper on the truck. Now, I realize that the Dana 60 is a super tough rear end, but I just use my truck for bringing home stuff from Home Depot or moving a chest of drawers, that sort of thing. I don't tow anything or carry huge loads. So, for me a least, the D60 was overkill. I didn't like having 8 lug in back and 5 in front. I also didn't like the 16.5 inch wheels. The tire on their gave the truck a "jacked up" look that I didn't want.
I found a 9 inch rear end at the local pic-n-pull during one of their 1/2 price weekends, so it only cost about $75. I also decided to replace all the bearings and bushings (axle and leaf spring) and rebuild the brakes while I was at it. I don't really have an overall budget for my truck, more a monthly budget. I'll tell you, all those bearing and bushings, brakes parts, new U-bolts and particularly the machine shop time (for pressing off and on the bearings and bushings) really adds up. I don't keep receipts, and I did this project over several months, but I estimate all in I'm up to $650 - $700. That is with new everything except the springs and the axle itself. New shocks, new drums, etc, etc. etc.
As far as the difficulty of the project, I would say it's not too hard. This was the first time I had done this and I ran into the following problems:
1. I couldn't separate the two driveshafts. After years and years of no lubrication, they had fused together at the splined shaft. I ended up taking them to a machine shop and they separated them for $35
2. My parking brake cables that I bought are not long enough. I still haven't resolved this but plan to use extensions that I'll either buy from someone here or get from inlinetube.
Other than that it was just a lot of work. Removing the ubolt nuts took a long time and a lot of strength.
I should add that many people here helped me over the last few months and this website was invaluable.
On to the pictures!
Here is the 9 Inch I got from the junkyard.
Lots of sanding with the paint and rust removing wheel:
Done!
Painted
I learned that I would need a different driveshaft because the D60 driveshaft is shorter. I bought one of Keith's:
Stripped
All painted up and shown next to the D60 driveshaft, for reference.
I also bought some wheels from a junkyard.
I could not remove the brake hose without stripping the fitting so I replaced the brake line back to the center connector. I think it looks pretty good.
Here is the brake rebuild
A "before and after" shot
Here is the finished product:
Before with the D60
And after with the F 9Inch.
After reviewing some of my reference photos, I realized that I have the parking brake cable routed incorrectly. I will fix that when I get the extensions.
Last but not least, here are the before and after shots of my truck:
BEFORE:
AFTER
It might be hard to tell from the pictures but I really didn't like those big ol' tires that were on there before. I'm going for a very stock look and I'm really pleased with the results.
As you can tell, I'm not doing a frame off restoration, so I haven't touched the frame. I'm replacing all the deteriorated parts and just cleaning stuff up so it's no covered with 30 years of dirt. I hope to have a decent looking driver when I'm done.
Let me know what you think.
On to the pictures!
Done!
Painted
Stripped
Before with the D60
BEFORE:
AFTER
re: 1968 F-100 Ranger - Picture Heavy (4-2-2006 update)
the hole truck looks alot better good luck with your future projects
- trukcrazy
Very nice dc, I think it is coming right along. The new paint and rims really make a difference. Good "mod"
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- boots
nice work man!!! When I pull my 9" out to put locker and gears in it Im going to paint it just like you did.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Just a quick update. I replaced my rusty old mirrors with a set of stainless steal mirrors I purchased off ebay. I had orginally wanted to put a set of the small car mirrors on, but I decided that since I had all the holes already for these I would just go ahead with the camper mirrors.
I think it makes a big improvement in the look of the truck.
You can see the "before" pics just a few posts up.
- GT-Racer
re: 1968 F-100 Ranger - Picture Heavy (7-1-2006 update)
Nice job. Quite an improvement.
- Sharkdance
That truck is looking Fantastic!
I realise the time and work you are putting into it and man I gotta tell ya. Your doin it right!
Great job dude. Keep it up
- trukcrazy
You guys are making it look soooooooo........ easy.
I cannot get over the amount of work all of you are getting done on your trucks.
John, #424
- dablack00
Wow, the mirrors and wheels/tires make a huge difference. Truck is really starting to come together.
Austin
Austin
Just a quick update here. I haven't yet decided whether to replace the bumper with a step or sport bumper, so in the meantime I decided to improve the look of the existing bumper. I used a 3M paint and rust remover pad to remove any flaky rust and chrome. I used Krylon Rust Tough enamel in Aluminum color.
I think it turned out pretty good. I still want to get a chrome bumper at some point because this one is bent down, which is hard to see from this angle.
BEFORE:
AFTER:
BEFORE:
AFTER:
