1971 f250 DESERT truck- 10/24 race prep
- 03rangerxlt
Re: 1971 f250 DESERT truck- 8/2 carnage :(
man i hate that for you. hope you can find a tire toget you going again.
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
- OldRedFord
Sorry to see that Ryan. I wish I could help you out to get her right again.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- 1971ford
oh you should hear the oooootttther story.
In this shop, there is a huge shelf rack full of racing parts.
Rick, the owner, grabbed the whole rack with the forklift and took it to the dumpster and started throwing everything away because he didnt want to see it there anymore (rack was full of things such as a complete MSD ignition for my 429, and many other parts). Another guy i know stopped him and grabbed a handful of things but the rest is now gone.... so sad. one mans trash is another mans treasure
-Ryan
- aramil
theres water in your oil
j/k glad to hear you got some tires and i like the looks of them gauges.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
- 1971ford
Today i got the antennae for the GPS, can't wait to hook it up.
Also i picked up my tires! Did you know that 4 33" tires and 4 35" tires/rims fit in the back of a bronco if you plan it out for an hour?
so i trimmed the rear fenders and mounted them... man they are massive. way bigger than i thought!
I also started on my rear bumper. I only need about one more hour and i will have the whole rear bumper/tire carriers tacked together.
should be sitting like this soon... need to get the beams away from the bumps!
The bumper nerf hoop will be getting tighter bends to give it more space from the main bumper tube.
-Ryan
- aramil
Re: 1971 f250 DESERT truck- 8/5 tires
what is the rear axle in youre truck? its probly posted already but im feelin kinda lazy tonight
if its the 9" do you have any worrys about it holding up to the load the 35"S will put on it?
ive seen alot of them broke by 35s but thats usually on rock crawlers with some good power.
- jeepermc
I believe Ryan is running a D60 in the back....
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
1987 Mustang GT
- BradyCouchman
Re:
1971ford wrote:yep stock D60.RedneckTexan wrote:It's a F-250, but I think he's still gonna run the stock D60 though.boots wrote:You running stock rear 9"?
it has 3.73's which i planned on running but since we plan on 35" tires i think were going to need something in the 4.o's
yup a D60....
1970 Crew Cab 460CI 2WD
06 Focus Daily Driver
- aramil
i think it should hold up then, cant wait to see it in action.
- 1971ford
yeah the plan is to have it stay together
i have two spare axles that each chase truck will have just incase we feel like twisting some axles.
-cut/notched/tacked on spare tire carrier tubes, rear bumper, bumper suppors and plated rear of frame
-welded brace from bedside top to main hoop so that will no longer bang/flop around, i will probably add a gusset soon on the top of the brace. I may also add a large-tube gusset from bed floor, to bedside about a foot up.
-started patching all the cab floor holes. half way done, way too much exhaust heat, rocks, dirt and fumes comes through as it is!!
My 34's are obviously bigger, but they are a 3/4 inch wider too so they fit perfectly snug in the carriers, and the spare 33's half about 1/2 gap to one side when pushed against other side. air in the tires should help but they will not go anywhere with 2" ratchet straps cranked on them.
I am also adding two more tubes that will go from the bend on the main bed cage tubes down to the bumper to give the tire support on the inside.
some say they stick up too high, but i am leaving them like this. If i cut the floor out under them to sink them a few inches, i will be cutting out one of the few remaining bed support crossmembers and hte bed will start to fall apart. But, the way the carriers are made i can cut them out in the future and they will still work great.
i need to adjust the toe on the truck, im sure its off. it squats more than usual when reversed into driveway.
-Ryan
- 1971ford
-made lug wrench mount with T-handle
-fiberglass front fenders
-made a center console and supports
-All gauges work! Tach, oil pressure, water temp, volts, and trans temp (actually that isn't hooked up yet. need to do that). All lights work with the flip of a switch as well.
-wired some switches up. We have a switch for the horn (the old Start switch, it doesnt stay clicked on so its good for a horn), fuel pump, electrics on/off, gauge lights, and amber, which is also wired.
-rear bumper extension to protect fuel cell, still needs to be welded. We ran out of c02/argon!
-seat belts are all mounted with the exception of a couple tabs that just need to be welded on.
-Seat mounts just need to be welded as well
-painted bed cage because welds were starting to rust
lug wrench mount
High-tech state of the art zip tie mounting mechanism:
I don't have good luck with tires.
A nail is in this tire, we will plug it tomorrow. I think it is safe to say that during the race we will be swapping out a left front.
I have a blue vinyl im going to cover it in eventually. for now, paint.
Ammo cans will go here, and pumper will later go behind them. Real-size cup holders will go in front.
We have only one more weekend for getting the truck race-legal! Then the weekend after is testing. Still have many things to do
lug wrench mount
-Ryan
- Vinniesempire
Re: 1971 f250 DESERT truck- 8/16 tires
that is awesome. what shifter is that?
- trukcrazy
Looking good Ryan.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- 1971ford
Thanks
It is a Winters gate shifter. I have two, this one goes with this tranny, and i have the reverse pattern of this one for the built tranny. This tranny i can leave it in 3 and it still shifts auto because the valve body isn't full auto, but once the built tranny is in, we will be continuously shifting
-Ryan
